81 xs650 hs
- Messages
- 9
- Reaction score
- 0
- Points
- 1
Back Ground:
81 xs650 HS new top end bike rebuild. First time fire up having issues, did the normal motor freshen up, new top end, carb rebuild, ect.
8000 miles on the bike, bike stat for years
carbs are mikuni 34 cv
So My issue is the bike isnt getting fuel into the cylinders, timing is correct, carbs are spick and span, electrical is working great. But when I pull the throttle the carb slides dont move. I have taken the top side of the carb apart and the boot is good and sealed, if I move the slide up with my hand the boot seals and acts as its suppose too. the spring is in good condition. the slides arnt moving at all at anytime so im not getting any gas pulled into the cylinders and my plugs are dry. So What may be a problem? I am just running out of ideas and ways to solve them, if I use starter fluid the bike fires up on first kick.
any help or suggestions is appreciated
