Yes, it's a two step process, but you need to do the idle sync first because changing the idle speed changes the amount of freeplay in that carb's cable. That would throw off your "at speed" (slides lifted) sync. So, sync and match idle speeds then sync the cables so slide lift (or in our case, butterfly plate opening) starts at the same time on each carb.
