Normal, behind the LH cylinder is a very popular spot. More common near radius's and corners.
A couple of random quotes from the web about a "supposedly" cracked Miata oil pan.
"Both of the oil pans that I checked have minor flashing or webbing around the drain plug from the diecasting process. Molds used to diecast aluminum frequently develop spider-web cracks in the surface (heat checking) that transfer to the parts being cast. These lines look like cracks at first glance.
" I work for a company which designs and manufactures diecast tooling for various industries including automotive. Depending on factors such as severity of thermal cycling, part shape, die design, heat and surface treatments, etc.., die inserts will eventually start to heat-check. As diecasters come under ever-increasing economic pressures they tend to run more shots through their dies before a rebuild. It is not uncommon to see heat-check flashing on die cast aluminum parts these days. "
