Stock 1975 XS650 with about 13,000 miles, I'm the 2nd owner. Bought this bike in late spring. Most parts original. Decent shape mostly aside from a few fixed age-related stuff.
I've always noticed a consistent metallic chattering/clacking sound from the top of the engine, which wasn't exactly loud, but it was definitely audible. It was only mildly noticable, so I left it alone. From what I knew, it was the valves.
A few months later, I had some spare time and adjusted the valve clearances to get rid of the sound. The old valve clearances were within spec, so I adjusted the the valves a hair closer based on stuff I saw here on this site.
Some notes when I adjusted the screws:
Upon finishing, the chattering sound seemed just as loud, if not a little louder. The sound is always consistent and doesn't matter whether the engine is cold or warm. Oh well, the bike still runs, and at least I knew the valves were on-spec.
Here's a video of the sound:
http://s1159.photobucket.com/user/LarryGoesOnVacation/media/Motorcycle/IMG_2777.mp4.html
But now, after a couple weeks of riding, it seems *even* louder. Like so loud I'm a bit worried. Is this a valve sound or something else? Or is it something as simple as raising the screws higher, or getting new screws?
Thanks in advance.
- When I manually turned the engine counterclockwise at the rotor with a 17mm socket, everything seemed to be okay, no noise or anything odd.
- The rear valves I used a 0.075 mm (~0.003 in) feeler, the front valves I used a 0.1 mm (~0.004 in) feeler. The feeler resistance "scraped" through, the next bigger size wouldn't fit, the next lower size went in with no resistance. I made sure to do these adjustments right after the rear intake valve came back up, rotor lined up to top-dead-center.
- The tips of the valve adjuster screws (which seem to be original) weren't flat. They seemed to be worn to a slight angle (like a lipstick tip but not as exaggerated), so technically there's slightly more clearance on one side of the screw than the other. Since I adjusted the screws, the worn angles are now pointed at slightly different directions. Clearances were based on the closest side of the tips.
- There's evidence of very tiny amounts of oil weeping from all four valve covers. Not gushing, but like a dried-up "runny nose" after a long ride. The gaskets seemed okay but I can't verify their age. The valves and screws were moderately wet with oil, and the inside of the covers had a little oil inside, I assume that's normal?
Thanks in advance.
