davekeck
Hello! I'm having a charging issue with my 1982 XS650J and was looking for some feedback on my assessment.
Problem Background
My battery isn't charging because the voltage at the battery is 10.5V at idle and 12V at 3k RPM. When I unplug the yellow connector for the safety relay, the battery voltage is 11.2V at idle and 14V at 3k RPM.
What I've Tried
- Replaced alternator brushes recently and the lengths are within spec. Brushes assumed OK.
- Tested the regulator (grounded green regulator lead; no increase in voltage at battery at 3k RPM) and alternator brush wiring (connected brown brush lead at alternator to positive battery terminal; no increase in voltage at battery at 3k RPM). Regulator and brush wiring assumed OK.
- Resistance between rotor rings, brushes removed: 1.6 ohms (rotor assumed failing)
- Resistance between rotor rings and ground, brushes removed: infinity
- Resistance between white-white leads: 0.5 ohms
- Resistance between white leads and ground
-- Yellow connected: 22 ohms
-- Yellow disconnected: infinity
- Voltage between white leads at idle
-- Yellow connected: 8.6V AC
-- Yellow disconnected: 9.4V AC
Questions
To me these measurements suggest:
Is this a plausible assessment? How can I prevent the yellow wire from reducing the alternator's output?
Thanks very much!
David
Problem Background
What I've Tried
Questions
- The yellow wire is grounding the white stator wires, reducing the alternator's output.
- The rotor is failing based on the 1.6 ohm measurement, but works to a degree since it can still deliver 14 volts at 3k RPM.
Thanks very much!
David
