AllanCaveNZ
Hi guys,
Was putting my bike together recently and had a question about carb / timing and received a couple suggestions that were a heap of help so thanks.
I did the PMA / Pamco Ignition / Mikuni VM34s combo and trying to get it dialed in, it starts up best with the ignition set at the middle of it's advance (plate has equal room on left and right of the screw), and the right hand cylinder backfires until I tweak the carb to run a fair bit richer than the left carb, runs okay like that but a little lacking in power at lower revs.
I presumed this is a sign of average compression, did a compression test today and got a tad under 110psi on right cylinder and just a little over 100 on left cylinder, but didn't realise I needed to remove the spark plug from the opposite cylinder while testing, will this have influenced the test or just made it harder to turn over while doing so? Engine was warmed up fairly, though might have cooled down a bit by then. Cam chain / valve clearance adjusted fairly recently but could check that again before retest I guess.
Should I retest without the opposite plug in? Any thoughts on how challenging it is to do a top end rebuild having never done one before on any bike, but being moderately experienced with bikes otherwise?
Any advice appreciated.
