Crackers61
Crackers61
Hi Guys,
I'm having troubles trying to get my bike to run. The engine is a 75 model 447, newly re-built. My ignition timing is prefect, valve timing perfect too. Running points.
I'm running CV carbs 34mm. I've pulled them to bits cleaned them out, cleaned all jets and passageways, a number of times now.
The engine seems like its starving and struggles to run, sometimes i can get full throttle but not all the time. I've put this poor running down to the carbs.
Apart from the carb forums is there anything else i could try, without replacing the carbs?
Out of ideas?
thanks in advance
Crackers
Out of ideas?
thanks in advance
Crackers
