Quinn_McLeod
Gentlemen,
This may be a dumb question, but I started my motorcycle for the first time after a HUGH'S PMA AND PAMCO PETE INGITION overhaul. Started on the second kick
The left side clutch and chain aluminum side over was off at the time because I still need to install the chain. The clutch push rod (proper name?) which goes into the engine and actuated the clutch from the cable wasn't installed and when I started the bike, oil POURED out of it.
Is that normal? Do I have a bad seal? Or is it SOLEY because I need that push rod this to be sitting in there?
