The early models actually spec it a little tighter, 94 ft/lbs. That's what I use and it seals well. I started out using about 72 ft/lbs I think. I didn't get drips but there were always oil streaks on the sprocket emanating from the shaft. Upping the torque to 94 eliminated them ......
Since the leaks in that area are from oil running out between the shaft and the sleeve spacer, I now take some additional steps to seal it. I put gasket sealer on the back of the sprocket where it contacts the sleeve, and also on the back of the lock washer and the nut .....
