I offered up the fzr1000 discs with the spacers I machined and they went on beautifully, however, as other have no doubt discovered, the left disc bolt heads smack into the speedo drive. Are a set of button head Allen bolts all that are necessary to remedy this? Also, I have a set of second gen SV 650 calipers which will finish off the brake upgrade, and I'm wondering what is the best way to set them up. Do I retract the pistons and mount the calipers so the non-piston side is closest to the disc, or do I put the piston-side pad closest to the disc? Or is it best to bring the pads tight to the disc and lay out the caliper adapter based on a centralized caliper? I can't wait to see how these work out. I got them with braided lines attached, so I might just trim them to lenght and attach new banjo ends.
