Terry,
I am a bit confused about what you want to achieve. There are no hard rules regarding fork or shock length for any type of bike. Often will there be a conflict between a certain look and handling/comfort/ergonomics. There will always be some compromise involved.
Personally, I try to put priority on ergonomics and handling for my type of riding.
That is why I want the footpegs between the original footpeg mount studs. Handlebar type and position depend on footpeg position and vice versa.
For me, this footpeg location puts the pegs immediately my bodys centre of gravity, enhancing bike control. Then I choose a handlebar that makes me lean into the wind slightly, resulting in effortless cruising between 90 and 110 kmh.
A full on "cafe" setup with extremely rearset pegs (like TcBros) and clip-ons is really uncomfortable for any riding except really hard, aggressive riding. There are better bikes than XSes for that.
If you lower the front by sliding the forks up in the triple trees, make sure the fork does not bottom out on the dust seals. There is not much clearance left there. I suggest you remove the fork caps, and compress your forks completely to check this.
Depending on your front tyre size, front mudguard and exhaust pipe routing, you may have clearance issues in that area too.
