TwoJugs
Excess XS
I took the softail road after building one rigid and riding others. I still think hardtails look great but I like to ride and my worn body parts need comfort. My cheap solution was to strecth the swingarm 4.5" and use the stock shocks and mount points. The swingarm work took some time but most was my free labor. I found a way to take the stock shocks apart and strip them down and give them that old school look.
A piece of galvanized pipe "T" that fit over the shock top and in my drill press once the table was slid out of the way. Using the chucks travel I compressed the shock then went into the T and pulled out the retainer lock with an o ring pick. After that you can relase the pressure and take the shock apart. Remove the chrome cover with reflector, clean everything up and put on some fresh paint. Reassembly is a bit tougher. Holding alignment while working the clip back is a bit testy and dangerous so attempt at your own risk. It is best to have a second helper holding the shock inline. A little off center and this might take out an eye or tooth. It did grab my hand once, ouch!. Gloves, goggles and maybe a piece of plywood with access holes to work through would be advised?
The one thing I found out is the springs on the shocks really move around at certain RPMs. Enough to hit the shock cylinder and scratch the paint! Maybe the hoods dampened the movement? Using these with the strectched swingarm gave me the drop I wanted. I have them on the stiffest setting and still had to bend the back hoop up and inch or so for clearance. The bike rides very smooth and my back appreciates it. I am planning on doing another without the stretch and using shorter shock in the fiuture for a different look.
