Gofast Innovations JIS screwdriver and impact driver set Giveaway (ends 1/21/22)
Gofast Innovations is giving away their JIS screwdriver set, impact driver set, and 8-piece impact driver bit set to one lucky XS650.com member! If you're working on vintage Japanese motorcycles, you need to be using Japanese Industrial Standard (JIS) drivers.
Just post in this thread to enter the random drawing. Free shipping to the U.S. and Canada. Winners in other countries will pay shipping only. The drawing ends at 11pm CST on January 21st, 2022.
Good luck everybody and thank you to Gofast Innovations for sponsoring this site and its members with this giveaway! Check out https://www.gofastinnovations.com
Impact Driver - One 1/4” #2 JIS bit and One 1/4” #3 JIS bit
You’ve never seen an Impact Driver like this before!
Exclusive to Gofast Innovations this German designed impact driver weighs just 7.3 ounces. Other company’s drivers can weigh up to 23 ounces. This makes our impact driver much easier to keep horizontal when hitting it with a hammer to remove difficult screws saving you from hitting your hand.
The sturdy box contains one Gofast Innovations Impact driver, one 1/4” #2 JIS bit and one 1/4” #3 JIS bit. Guaranteed to fit every JIS and Phillips screw.
Gofast Innovations JIS Impact Driver Bits (1/4")
Each set contains the following:
4 1/4" - #2 JIS Impact Driver Bits ( 2 Short 25mm & 2 Long 75mm)
4 1/4" - #3 JIS Impact Driver Bits ( 2 Short 25mm & 2 Long 75mm)
Packaged in a sturdy plastic box.
Gofast Innovations JiS Screwdriver Set
1-JIS style screwdriver-size #1 with a 75mm shaft, perfect for those little screws on handlebar switches, electrics, etc
1-JIS style screwdriver-size #2 with a 100mm shaft, our most versatile, great for all carb screws, etc
1-JIS style screwdriver-size #3 with a 150mm shaft, fits all those larger screws found on the engine cases and bodywork.
When you receive your Gofast Innovations JIS screwdriver set and open the box, you will find the best set and maybe the last set of screwdrivers you will ever buy. That’s because JIS screwdrivers fit most Phillips screws too.
I use mine every day and love it but only have the one size and it’s getting old now so would love these in my tool kit..
Don´t know about Jizz, but I could certainly need a screw driver... :cool:
Can always use a good screwdriver set. Looks interesting.
I ain't never won nothin before. might as well sign up to lose this too. Congratulations somebody else.
So this way I will be able to compare with the Vessel JIS impacta screwdrivers set of a friend of mine …
I've always wanted a proper set of JIS tools. Then I can stop using inappropriate equipment on my Japanese bikes!
