Unclesol will be happy to see that I'm making progress with mounting the new tank.
The mounts I had previously welded into the frame for the old tank worked out great, and had enough adjustability built-in to be used with just about anything, but...
The new tank, after some strategic reshaping, required new mounting points to be welded in to match up with the existing mounts on the frame. This means more fiddly metalwork and welding deep in the tank tunnel, where both will be annoying.
So, I came up with the idea of a "saddle" of sorts; a shaped piece that snugly conforms to the underside of the tank/tunnel, while also attaching securely to the mounts on the frame. This is what I've gone forward with so far:
I layered in a barrier of Mylar tape over the area of the tank tunnel where the saddle will fit. Then, I made up some paper patterns before cutting the shapes out of carbon fiber twill cloth, saturating in epoxy, and pressing into place.
The laminate was covered in PeelPly, then weighted with a plastic bag tamped full of sand. A vacuum bag would have been better, but a bunch more work.
After the first layers of carbon were starting to kick, I laid in two more strips along the sides, and smoothed them over with more PeelPly.
Wither heater blasting away, the epoxy kicked reasonably quickly, so I pulled the PeelPly and popped the saddle out of the tunnel and removed the Mylar barrier. The saddle still has a few rou edges; every time I pulled it out for another fitting, I trimmed and sanded a bit more...
Here's a trial fit, right-side-up, on the backbone of the bike:
The Mylar had a few wrinkles, which kept me from a "perfect" finish, but no worries; this is a structural piece, not something for show!
Next, I started in with the cups that will fit over the posts that are mounted in the frame. I'm bonding in a single tubular piece, which will keep everything aligned. Afterwards, I'll cut out the center section to form two hollow stubs.
The tube is also carbon, with a Kevlar overlay. Right now I just have it tacked in with a few drops of epoxy; next, I'll finish with a proper fillet bond and a little more carbon.
