Help me find spark on my SR500
"I probably misstated earlier about power the coil. I believe what he did was bypass the harness and went straight to ground and coil. "
The spark happens only when the power is broken to the coil. If you supply power to the coil to continuously (with two wires) I think you run the risk of burning it out. (others with more experience may confirm). Depending on the sequence of events you may have ohmed out a good coil and then burned it out by running seperate wires.
This is where the 12v comes in from the mysterious system "down below". If you are not getting a pulse of 12v from these two black and orange wires as you kick the bike over with the ignition on, then I would have thought this is where the fault lies.
Others with more experience may care to dive in here. :)
Dave
Some random, thinking out loud questions, for when we do the next round of tests.
- If spark is killed by grounding the CDI (yes, we tried the trick of removing the ground wire), if the main harness has some unseen ground....say, along the frame or in the headlight bucket....would that kill the spark?
- If so, would the harness test good for continuity (it does)? Also, the tests that Rex's has for the ignition switch and RH control/kill switch are done at the rear of the bike, back where the stator and CDI plug in. That takes into account the wiring harness. But we've tested each component separately too. Would an unseen ground that kills the CDI have shown up during those tests?
Hi Scott - did you ever get a fix for the no spark. I'm going round & around trying to get a spark out of my Suzuki GT500 and it sounds like I'm having a similar issue. I've replaced almost everything other than the flywheel rotor.....correction I think I have replaced everything but the flywheel rotor!!!
The flywheel was rewound improperly by Rick's. Three times.
I got my money back and Rex's did it properly and I got spark right away.
I got it running but never got carb settings just right for easy starting. I just about ruined my ankle working on the thing (it's still messed up) so I sold the bike.
I had this exact issue with my SR500. The difference being that I had all the surviving parts from a crashed SR500 too and so I knew that all of my spare parts were running ok immediately prior to the crash. This made the process very very simple. I just substituted spares on by one until the bike ran. It was the ignition pick up coil on the stator which was the culprit. The remainder of the stator was fine. It sounds to me like you've tried to replace anything which could cause the issue and so the conclusion is that one of your actions has yielded misleading results. My own suspicions are the pick up coil on the stator or the electronics which receive the signal from the coil or the low voltage wiring between the pick up coil, the ignition unit and the coil having a break in it.
