Biggles
I'm new here - I have a 1980 2FO model with BS34 carbs. The symptoms are a huge miss like a dead cut at 2500-3500 rpm on small throttle openings. I researched here and pulled the carbs apart and cleaned etc. The needles were worn, the pilot jets were out of the BS38's, one diaphragm was leaky, the main jets were dodgy, the mixture screws misssing rubbers and the air filters disintegrated.
So new diaphragms, new Canadian needles and needle jets, new mix screws, set floats, 42.5 pilots, 135 main jets and mikes pod filters. Still the miss! Carbies balanced on my water manometer, mixture set using dead cylinder method.
This bike has the TCI ignition. The coil is off a GTR1000 Kawasaki but is a 2.5 ohm one and a substitute Honda one gives same results.
I am stumped! What next?????
Biggles (from Darwin, Australia)
