Hey guys, bike is '79, with BS38, pods, open pipes, 140 mains, 30.0 pilots. Just installed Pamco, with mikes 17-6822 coil. Read through all posts on idle and timing. Bike tends to idle up as it warms (read thats normal) sometimes I rev it, and it stays high, then drops to low idle. (possibly indicating a lean condition?) I do not have a tach, and am trying to set timing. If I get it to idle around what I think 1200 is, as soon as I adjust the plate to change timing it also changes the idle, which in turn changes the advance.
Is it normal to have the idle change when you adjust the timing?
Does the idle have to be right at 1200, or can it be a bit higher or lower, as I say, I have no tach?
When does the timing actually start to advance, is it immediately after 1200?
If the idle was at 600rpm would the timing be the same as 1200? I'm assuming yes because rpm causes advance mechanism to operate.
Also I read in the carb guide to adjust mix screw to 2 1/4 turns. This may sound stupid, but my mix screw has a plastic cover that only allows it to turn maybe 3/4 of a turn, assuming I'm adjusting the right screw, what am I missing here?
Some places I haven't checked yet, but will:
Advance mechanism, carb butterfly for complete closure, starting fluid for leaks. I've had boots off enough times, and they looked fine, but will try the spray method.
Appreciate any input to get this baby to idle, and get it timed properly.
