Hey no problem mike! and welcome back. What plug # you using ? Looks like you have BPR7ES. Have you ohmed out the plug caps? With those plugs your caps should not have any resistance. If you are using stock BP7ES then you should be seeing about 5K ohms in the caps. Unscrew caps, check that the wire end is clean and making good connection inside the cap. One issue may be using resister plugs AND resister plug caps together that can make resistance high enough to cause misfires..
