Measured from the gasket (gasket is in place in the photo) to the end of the jet is almost exactly 3/4".
Is this a Z-6 Long or a Z-6 Short needle jet?
Thanks.
Yes, very helpful.I had the 73 set on my 75 when I got it. The only thing wrong with them is the throttle shafts have worn the holes in the carb bodies. It takes the first 1/8 to 1/4 turn of the throttle to lift the shafts before they start to turn. They leak air very badly. Seals can't seal with that much movement.
Interesting. The 1976 set I rebuilt had chromed float bowls. What's funny is that they didn't bother to remove the jets before chroming. One jet had to be removed with an easy out. Fortunately, the jets protected the threads in the bowl bodies, but I had to chase the drain plug hole threads.Mine also have chrome plated tops and brass plated throttle cable holders.
Interesting.If you need to rejet that set because your buddy has mods, be aware that you won't be able to run mains up around 140 like on newer sets. That large Z-8 needle jet will prevent that. Best I could do was mains in the low to mid 130s.
