The test to run now is to grab absolute full throttle at about 3.5K and run up to about 6K. You can do this in one of the middle gears (2nd, 3rd, or 4th). What you're testing here is the midrange to main transition. If the mains are too big or the midrange too rich, you'll get some stumbling or gurgling in the 4 to 5K range. Since you've already leaned the needle, your only option would be to reduce the main. You could lean the needle another step if you feel you absolutely need that main for the upper top end but personally, I don't like running the needle at either extreme (1st or 5th slot). I look for the largest main that will pass this test with the needle leaned one step. On my '76-'77 carb set, that was a 132.5.
Due to the forgiving nature of these CV carbs, it's important to use full throttle for this test. Lesser amounts may not show the glitches.
