Guss80special
Hi. So I’m hoping for some advice with a leak. I noticed the other day about 2 tbls of oil under the engine. This is more than normal. It does leak a bit normally. I thought it was the clutch push rod seal and do plan to replace. But now I’m worried I have bigger problem.
2 weeks ago I jacked the bike up with a 2x12 under the frame to put on some gaiters. After, I noticed some small dents in the wood where 2 of the case nuts are. And now (2 weeks later) I’m seeing more oil than usual.
Q: would a clutch oil seal leak in the dead of winter? Would the sump filter cover leak more with changing temps? Calgary gets lots of variations. Sometimes 20+ degree C changes in 24 hrs. I did replace sump gasket, 6 bolts and filter last sept. Maybe I didn’t clean the surfaces good enough?
Do you think I buggered the acorn nut? And would it leak from there? This is a case bolt right?
Note, upper acorn was already crushed a bit. PO did have crash, so likely from that.
Oil seem to drip mostly from that 3rd non acorn nut (finger). Another case nut?
Last fall folks on here thought that a drip there indicates clutch push rod seal issue. I agree, as it leaks lots when warm,but would it leak in the winter like this stored on the center stand?
Also. “2Many” thinks that the lower acorn looks suspect. Thanks for any tips!
Thx.
Pics attached.
Thx.
Pics attached.
