marvintheminnow
how do i measure the floats on the BS 38's.
here is my assumption:
remove bowls
place carb upside down on flat surface
with the float now resting on the needle measure from the rim where bowl gasket lines up to the float.
im not sure what part of the float your suppose to measure to or if the float should be in the upside down position resting on the needle.
remove bowls
