New M/C, new SS line, fresh piston and seal. The brake worked great for nearly 700 miles this summer then started dragging yesterday. Dragging badly. I borrowed a crescent wrench and bled some fluid off to get home but I wonder what is going on.
No.When you opened the bleeder did you see any air come out?
I assume that if I can see the MC piston through the port sliding past the port as I squeeze the brake lever that the port is clear. Am I missing something there?New MC my bet is a plugged relief port from bore to reservoir the second TINY port. Been there a bunch of times.
yupI assume that if I can see the MC piston through the port sliding past the port as I squeeze the brake lever that the port is clear. Am I missing something there?
Called the "compensator port."but the second TINY port.
Unless you're a Harley tech writer? I think both terms are used, I'll toss balance port in there as well.Called the "compensator port."
The "compensator port" is also referred to on boards like this as the spooge hole. The tiniest of particulate matter can plug it up.New MC my bet is a plugged relief port from bore to reservoir the second TINY port. Been there a bunch of times.
spooge hole gummed ??Riding cross country on a venture Royal the clutch started slipping a bit, the next day it was fine, then slowly got worse as I rode (Highway not clutching).
Problem was?
Poked with a fine piece of wire, except for an eye full of brake fluid (clutch control used DOT4) that squirted out, all good.spooge hole gummed ??
There will be a second, smaller port in there. The large hole is to allow fluid into the backside of the piston... otherwise there'd be a vacuum behind that would interfere with the piston sealing. You want to find the small one. That's the one that supplies fluid to the caliper.I have an aftermarket 12.7mm MC. The make up port is quite large and clearly open. The reservoir isclean. The caliper moves freely in the carrier and bubbles don't come out (I bled with a section of clear tube),
