mrob24
Good evening, All. First to my first ever thread on this page a few weeks ago, I've got the engine out of the frame and up on to my work bench. I did it solo, and it was up there with some of my dumbest moments. I think I nearly passed out while lifting it from the floor up on to the bench . Still, got there in the end, and without a hernia, too.
I've got the top end disassembled. I referenced this forum for several little parts along the way and picked up some excellent advice, including using a 6mm bolt in a puller guise to get the rocker arm sleeve from its housing. Now that I've exposed my pistons and the bores, I don't really know what I'm looking for, however my gut tells me what I've found isn't ideal... 1976 XS650 with (allegedly) 28k miles on it. I've owned the bike for approximately six months. The piston skirts look badly scored up to me, and the scoring is enough to catch a finger nail when gently running across the surface. Please see the attached photographs. The bores don't look too bad - there is still some cross-hatching evident, superimposed by some vertical scratches that seem 'surface level' only. Can you tell I don't really know what I'm talking about?
I'd appreciate it if your great collective knowledge could shed some light on the condition of my pistons, and subsequent next steps. Further, if the pistons / rings etc need renewed, what work has to go with it? My engine is standard, as far as I'm aware, and has 477-type con rods.
I'm new to all of this. I've read countless threads on here about top-end stuff, all relevant sections of the Haynes manual etc., but I'm a bit overwhelmed by all the information.
Thanks in advance for any advice you can provide.
Cheers,
Mark
Cheers,
Mark
