Fleksta
I've finally put my bike all back together and found that I now have a problem with it slipping out of neutral.
I expected to see the detent spring pop up with the bolt removed, but no dice. Am I correct in assuming that it should have done so (i.e. the bolt puts pressure on the spring)? Or does the right side cover need to come off to get that spring and detent out?
Just wondering if I may actually be missing that spring. The PO must have had that bolt off in the past, as it also had no gasket on it.
