New Last Build Thread "maybe"
Polished the chain guard and fit the megaphones for a visual. Their OK I guess.:shrug:
Built a couple of stand off`s to use rubber isolator`s to mount the megaphones. As much as I`d like to change my mind about the exhaust I`m going to live with it. (For Now anyway?). A new Morris Magneto is now $1395.00:yikes: and a new Earl`s oil cooler is $195.00. Looks like the First Tracker is about to loose some parts. That`s OK though because it needs another make over.:thumbsup: Brake cable has to be a 7mm 62" outer shroud and 66 1/4" 2mm inner cable. Motion-Pro cable shroud is $46.00 for a 50 foot roll. $22.00 for the inner cable and who knows how much for ferrules and cable ends. Probably a couple hundred for clutch, brake and throttle cables.:doh:
DSCN1866-001.JPGDSCN1867-001.JPGDSCN1868-001.JPGDSCN1869-001.JPGDSCN1870-001.JPGDSCN1872-001.JPG
Made a mount for the rear master cylinder and drew out a pattern, cut it out on the band saw and bent up a mount for the oil cooler. Now I`ve got the rest of the evening to decide whether I like it or not and change my mind.:shootme:
View attachment 302788View attachment 302789View attachment 302790View attachment 302792View attachment 302793View attachment 302794View attachment 302796View attachment 302797View attachment 302798View attachment 302799
It needs more holes...:)
Today I bought a donor parts bike. New (2 weeks old) Mikuni VM34`s from TC Brothers and a Hughs HB CDI ignition kit compatible with a Lithium Ion battery. Don`t ask me how but this thing started easily and runs. I`ll rob the carbs and CDI to use on my 1st tracker when I remove the Morris Magneto and the Gary Hoos carbs. Along with the stock parts were these carb needle & jet kits. I don`t think their for the VM series carbs. Must be for stock ones. It was a Heritage with buckhorn bars so I didn`t bother to take a pic of the whole bike.:laugh:
DSCN1916-001.JPGDSCN1917-001.JPGDSCN1920-001.JPGDSCN1921-001.JPGDSCN1925-001.JPGDSCN1926-001.JPGDSCN1928-001.JPGDSCN1929-001.JPG
Made the bracket for the brake cable and did the final cut to length (66 1/2") and it works just great. Made up the oil cooler lines. Everything I did today turned out just fine.:thumbsup: What`s up with that?? Tomorrow front tank mounts (might go with 2 smaller tanks) and lifting spool brackets. I`d like to get all the brackets and parts done by the weekend and ready for the final welding. The tail section in a real SOB so it`s on the back burner for now.
DSCN1932-001.JPGDSCN1933-001.JPGDSCN1934-001.JPGDSCN1938-001.JPGDSCN1937-001.JPGDSCN1939-001.JPG
I haven`t touched the LSR build in over a week. Went in the garage today and cut out the seat/tail section. Welded on a couple of mounting tabs and cleco`d it on, stood back, looked at it and promptly threw it and the pattern in the trash can where they belong. Too busy, too square, too sharp edged, to something.:umm: Anyway I just didn`t like it.:shrug:
View attachment 312519View attachment 312520View attachment 312521View attachment 312522View attachment 312523View attachment 312524
Do other LSR bikes locate the oil cooler in line with debris coming of a front tire at high speed?
I haven`t touched the LSR build for 2 weeks following the seat/tail section fiasco "Builders Block". Anyways I`m back on it. Got the tanks made so now I have to decide whether I like them or not? Lengthy process. Can`t decide if I like the "Stack of Dimes TIG look or not. Smooth and polished is my go to standard so that`s probably what they`ll get.:thumbsup: Tomorrow I`ll re design the seat/tail section rounder, shorter, lower etc??
DSCN2268-001.JPGDSCN2269-001.JPGDSCN2263-001.JPGDSCN2264-001.JPGDSCN2265-001.JPGDSCN2262-001.JPGDSCN2261-001.JPGDSCN2260-001.JPGDSCN2266-001.JPGDSCN2267-001.JPGDSCN2271-001.JPG
