First start from cold, it’s rare that I can go from the electric foot. Once warmed up, it’s fine.The battery on these isn't very big so it doesn't have a lot of reserve. The ignition needs battery power to function for starting. Run the battery down a little bit with sustained cranking and there may still be enough juice to spin the starter, but none left over to power the ignition. The bike will crank over but not start. That's why kicking is good, it uses no battery power. In colder weather I always kick mine for the first start of the day. Once the oil has been warmed up and thinned out, the starter will crank and start it just fine.
The factory Service Manuals had cable & loom routing diagrams. That harness should be a fairly good reproduction (AFAIK) and route the same. I can upload such a diagram for an '80 if needed; you'll have an extra lead for side-stand switch, etc.I’ve ridden the bike now and am happy pretty much- the dual carb balance of idle and setting mixture screws seems fine for shakedown runs and to blow gunk out - new oil - filter on the way - oil was clean and tires old but like new so maybe it had maintenance etc…
The previous owner had toggle switches installed and wires jumped at corroded connectors in spots - he said it had a hot wire he couldn’t find and the toggle is his solution- its now burning fuses so im onto electric work and tracing bars etc find the pinched wire likely- was running fine - idling etc but fidget the thing enough im sure its not right electrically- anyone have experience with this harness lining up with their stock 83’
Thanks
