Actually it doesn't lead anywhere. If it lead some where the oil would flow from the oil line into that hole and go somewhere.
It don't work that way. Oil flows up out of that hole to the oil line to deliver oil to the head.
If you look in the diagram gggGary posted oil flows from the pump to the filter to an oil gallery that runs across the engine This oil gallery Feeds the oil line to the head as well as ports that squirt oil on the rod big ends. There are passages of this gallery that feed oil to the two center crank bearings. At the end a passage feeds oil to the left side crank bearing and back to the transmission.
Technically when you start the engine Oil flow will push anything you got down that hole up and into the oil line to the head.
Flushing the stuff out will push the stuff not just back to the oil filter/pump but into the crank bearings and tranny as well as run out the ports for the rod big ends to run down into the crank case.
If I was worried about a bit of stuff falling in that hole I would use a vacuum.
