Painting Tins. No really...
What color should these tins be?
  • Candy green and white a la XS1
    Votes: 15 28.8%
  • Candy gold and white a la XS1
    Votes: 20 38.5%
  • Candy red and white a la XS2
    Votes: 17 32.7%
  • Total voters
    52
So.... 'splainin' time....
This was Jessee's tank a few weeks ago....
Had a few dust nibs to take out, but otherwise done. While I was cuttin' the nibs out, I noticed this.....
Fuck me.... a bubble in the paint. :er:
It ain't gonna go away all by itself. Time for surgery...
As y'all can prolly guess, I was spittin' nails.... :banghead:
So, I walked away from it for a while.
Finally came back to it.... feathered it out, reprimed and filled it back in.
Candy's aren't receptive to blending. At least I've never mastered 'em. I masked off just on the edge of the inner white stripe and re-shot the candy. I'd already masked a line just inside the large white line. Pulled the inner mask off and shot clear to the overlap on the large middle white.
Sumbich if it didn't work.... better than I hoped actually. Just spent half a day feathering out the clear overlap and doing a cut and buff over the entire tank.
Took it out in the sunlight.... the top's an exact match to the sides.
When I first saw the bubble I thought I was truly fucked..... sand it down and start over.
@JesseeS , it'll be on it's way to the shippers first thing in the morning.
Never say die.... :cheers:
Well done. :thumbsup:.........and people generally/often complain about how much a good paint jobs costs...........
Was wondering if you were doing the stripes..........kinda think another unusual colour would have gone with the purple to add to an unusual concept of the whole thing
Awesome repair!
You've given me some hope that I can get a similar result on a "spot repair". I've got two (~4mm) spots (one each tank) on my homemade tank that the paint has bubbled. It’s been several weeks and they’ve not grown or changed. The spots are along the top and side panels’ weld seam. I pressure-tested to 10psi before first primer (epoxy), but apparently fuel vapor found a way (IDK). It’s solid black base coat – easier than your candy. If I’m lucky, I’ll avoid stripping the whole thing.
Awesome repair!
Thanks! If I may....
You can re-pressurize 'em and watch the bubbles. If they start growing, you've got a weld to fix.... if not, feather 'em out and re-shoot.
Fwiw, we NEVER went higher than 2.5psi when checking tanks in the airplane world.
Thanks. Will do.
It was maybe 3 weeks from painting to introducing first fuel. I was thankful for no leaks. Bubbles appeared a few days later after 2nd test ride. Now just over 100 miles, no change.
I only want to redo this once if possible, so I'll pressure to 2psi and watch as you suggest. Pressurize for what time period please?
Thanks. Will do.
Standard procedure is to pressurize then start spraying soapy water over the welds and connections. If there's a leak, bubbles will form immediately.
I think if I were you, I'd pressurize, soap the (paint) bubbles and watch 'em for a min or two. If there's no bubbles from the bubbles... :cautious: .... stick 'em with a pin and soap again. If the seam's leaking, you'll get (soap) bubbles immediately.
To answer your question, there's no time limit... as long as it takes.
I don't know about you, but when crap like that happens to me, I drive myself nuts analyzing it trying to prevent it from happening again. Most times I can't find a reason. Thankfully, if you're using quality products, it's a pretty rare occurrence. Nice save!
Thanks!
Yeah, I did a LOT of head scratchin'.... :umm:
Dunno... like you said, most times you can't figure out a reason. Thankfully that's something that rarely happens.
Thanks!
That reminds me of a series of blisters I saw once on a hood. There were 4 oval spots about 3/8 of an inch in diameter, fairly evenly spaced, but in a slight arc. Finally figured out that it was finger prints caused by skin oil/salt. Since then, right before I shoot, I wash it down with an alcohol/waterborne cleaner or a good foaming glass cleaner without ammonia. Takes skin oil off far better than wax and grease remover. Haven't had a fisheye in years.
