painting
Rattle can it! If you do not like the results then you will not have wasted too much. I painted my XS1B in 1984 using a spray gun that resembled a jam jar and was an accessory for a vacuum cleaner. It used the output air from the cleaner. What a crappy spray gun but I still managed a nice single coat job i.e. no clear coat needed. Now years later after spraying many paint test panels with minimal training I could probably do a damn good rattle can job now.
Yup, I think a rattle can job with 2-part primer is where I’m headed on the ‘81 Special to Cafe bike The photos I’ve seen on the Forum have inspired me!
Now....colours.....hmmmmmm
If I were to do a rattle can paint job I would definitely make a metal or wooden jig/fixture so that I could rotate the tank while working. The fixing points would be the 3 tank mounts. This will avoid having to spray at an awkward angle and save you accidentally touching the wet paint.
Here's my tank painting gadgetry.
A 2" disc of plywood, with a 1.85" bevel, 1/2" allthread, metal things.
For cleaning, derusting, sealing, a 2" plumbers test plug will just fit in the filler neck.
The tank hanger jig clamps onto the filler neck.
Once tightened up, you can just hang the tank, or grip the allthread rod and wave the tank about for more excitement.
A note about metal flake paints. The flakes do a laydown based on how the tank is oriented. The flake job will look different if the tank is hung vertically, versus shot while horizontal. Not the same as regular solids and candys...
That is interesting about the metal flake, I guess I would do a test piece of scrap or probably a can to get the look of curves, one flat one on end and compare. Always useful information for the memory bank on here.
I have been playing with this for a while, I am not a painter but am learning.
You need a large tip on your gun to shoot metal flake, I use monster flake -Bass Boat Style and need a very large tip.
(I use three different guns with diferent tip sizes)
1. sealer primer
2. base coat ( similar color to the flake you are going to use)
2a. tape off designs, re- tape designs, start over, watch youtube
3. carrier coat mixed with metal flake- (similar to a base coat without any color in it)
4. bury flake with 2k clear ( several coats)
5. redo, repeat, redo, repeat.........
I have spent hours on this and would have been way ahead to have taken to a shop. I just wanted to say "I did myself" crazy ?
[QUOTE
I have spent hours on this and would have been way ahead to have taken to a shop. I just wanted to say "I did myself" crazy ?[/QUOTE]
Not at all! I think we all have done this for one reason or another. Rebuild the engine, customise the frame, rewire. So we can say "I did that!!" Maybe chuff out the chest bit too...
1. sealer primer
Might be a little crazy!:D It’s just a tank and a couple of fenders. I’d reserve the “guns” for larger objects like cars and boats. The metal flake sometimes requires two coats to get it even. Keep in mind If your shooting automotive paint with a gun you have to mix and measure and not to mention buy all that stuff. By the time you’ve measured and mixed the paint and thinner and charged up your compressor you could have laid down two coats with a can. The only pictures i have are of my station wagon wheels. The dirty one is what they looked like before. Rattle can, metal flake. The hardest part about painting is the prep work!!!:bike:
1. sealer primer
I have never shot the really big flakes but I have shot metallic paint before, it's been a while but I imagine the technique would hold up today. When you spray metallics the same way that you would spray solids, the metal flakes want to go right to the base surface and essentially lay flat, not giving you much sparkle. The technique I learned from another painter was to first spray on a wet layer, then immediately back the gun away from the surface and spray a sort of fog coat. The paint has to be wet to do this. This lets the metal flakes land in the wet paint and assume a random patern that will reflect light from all angles. It takes practice to get the hang of this, but it works really nice and your metal flake will really pop!
I have an extra tank and set of side panels for my old guy and you all inspired me to try to paint it up myself. I have a little pressure sprayer I used to put lacquer on woodwork so I think it would work for pain.
Dozuki - Go for it! You can always repaint it if you are not happy. Do some tests before on something round like a big round can to simulate the tank.
Well wasnt a 650 but at least an XS..........my painter flaked on me so decided to try one myself........well it was all bomb can and actually turned out ok for a side yard job with no booth........
View attachment 124376 View attachment 124375
Some of my best paintings were done like that before I started doing it for a living. This was spray bombed in the yard with duplicolor.
