I recently installed a PAMCO with the E Advancer into my 1981 XS650 sp2. Bike still has the stock rotor.
I've had the VM 34 carbs though for some time, and know the ins and outs of those pretty well.
My question is this, after installing the PAMCO, the bike started and idled extremely well with the timing advanced. If I retarded the timing by turning the plate counter-clockwise in order to get the timing marks to align, the bike would stall, rpm too low. On VM-34 carbs idle is set by physically raising the slides with independant idle screws. In order to keep the bike from stalling with the PAMCO I have to raise the slides a significant amount more than when the bike was idling at around 1000 - 1200 rpms with the stock TCI.
The slides are so high that I am getting some hanging idle upon throttle release in order to match the timing marks. Is this normal or common when using VM34 carbs and a PAMCO?
Thanks.
Update....Sometimes I rush into things and then after sitting quietly at midnight things occur to me. When setting timing is the "U" symbol on the stock rotor the advance timing mark, or the idle timing mark? The PAMCO instructions say to use the "F" symbol, but the Specials do not have an "F"
Update Update, I found the answer in a post from 5twins
I assumed the furthest mark I had was for advance timing, apparently the TCI bikes do not even have one. Thanks 5twins.
Thanks.
You are going to want to check the full advance setting. You don't want to be running the timing too advanced. There was no full advance mark on the later bikes but you can use the left side of the drain notch on the bottom of the cover opening .....
