GL1000 factory service manual, rectifier positive wire IS connected between the battery and main fuse, many others are done the same. Rotor, stator, reg/rec, same type of charging systems.
If you didn't have fuses in your house, when something happened to your wife's iron, say its heating coil broke so that instead of having some resistance it became a short, there's a chance the wiring inside the wall would heat up or burn in two and spark and cause a house fire. The purpose of the fuse is to safely burn in two and cut off the power before anything can happen to the wiring. Current through something causes it to heat, and the more current the more heat. The lower the resistance, the more current. A short, 0 resistance, is maximum current. Thick wire can handle more current than thin wire, so the thin wire fuse burns in two and saves the house wiring. You'd want the fuse as far back as possible so that it would catch everything -- not leave some outlets unprotected. Modern houses use circuit breakers instead of fuses, but same difference.Just so interesting, is anything really protected either way, is the question to ponder.
Scott
If you throw a short across the battery, something bad will happen to the battery. If batteries never exploded and were free I'd agree the battery doesn't need to be protected from that. The fuses on these is actually protecting the battery too...The battery does not really need to be protected except from going flat and the regulator takes care of this.
No, the fuse(s) on a motorcycle/car/truck, do not protect the battery. If you drop a wrench across the 2 battery terminals in a bike/car /truck, there will be arcing and the wrench will likely melt or the battery may explode. Its the same for the large cable that runs down to the starter motor. If that cables copper wire touches ground while the push button is pushed, a huge current flow will occur and the cable may melt and cause a fire.If you throw a short across the battery, something bad will happen to the battery. If batteries never exploded and were free I'd agree the battery doesn't need to be protected from that. The fuses on these is actually protecting the battery too...
Not sure about cars, trucks, and motorcycles in general, but in this particular layout the fuse does protect the battery. LOL. It isn't the primary reason for the fuse, but it does in fact have that effect.No, the fuse(s) on a motorcycle/car/truck, do not protect the battery.
Batteries are very rugged. If there was no 20 amp fuse, and you had a short to ground in the wiring, high current would flow, and the copper wiring would likely melt and thus open the circuit. If the wire did not go open circuit, and current kept flowing, the battery would fully discharge and likely could be recharged later. The fuse is not there to protect the very rugged battery.Not sure about cars, trucks, and motorcycles in general, but in this particular layout the fuse does protect the battery. LOL. It isn't the primary reason for the fuse, but it does in fact have that effect.
LOL. I said the same -- but I added that in this circuit the fuse does have the additional effect of protecting the battery from a short. You're saying a short across the battery would burn in two and fix itself, and it might or might not, but it's uncontrolled -- it was not something consciously included in the design and the reason for not using thicker wire was not so that it would burn in two. You're saying a (I assume sustained) short across the "very rugged" battery is not a problem. Charge up a battery and short it with a jumper cable and lets see what happens. You're saying it won't hurt the battery, and if you're right it won't cost you anything.The fuse is not there to protect the very rugged battery.
