The Yamaha engineers knew where to put a fuse, and how to wire a motorcycle.
Whenever you have a large power source, such as a battery, the positive terminal must be fused as close to the positive terminal as possible. The fuse must come first before any other wiring or components. Only the wiring and components down stream of the fuse will be protected. Any wiring that comes directly from the battery, will heat up and melt. The copper wiring of #18 or #16 or even #14 gauge will melt very quickly if there is a short circuit.
I've worked in various industrial settings, which had very large battery banks capable of 1000s of amps of current. The first thing you find leaving the positive terminal is a fuse. To not have a fuse as the first item in the circuit, means the whole building could burn down
if a short circuit occurs.
