No joy in Muddville.....won't start now. Plugged stock TCI in; vroom-vroom. Reconnected V11r, checked all connections and input voltage, re-checked values - nada. Garage door closed for today.
Well that's too bad....was hoping this might be a bit of a silver bullet ignition as replacement for stock TCIs. You throwing in the towel or gonna keep trying?No joy in Muddville.....won't start now. Plugged stock TCI in; vroom-vroom. Reconnected V11r, checked all connections and input voltage, re-checked values - nada. Garage door closed for today.
I taught MSF classes for 8 years, We taught that you SHOULD use the "kill" switch as it's there for emergency use and you do it with regularity for muscle memory. If you never use it, you'll not have the reaction to use it when needed. I've worked on many cycles over the years and only saw one in all these years where that switch actually failed.Why not use the kill switch? It is unlikely to wear out. On all my bikes, I always stop the engine using the kill switch (2 Ducatis, RD350, XS650) If anything, using the switch may prevent problems.
A great sign that Theile is so responsive. And why am I not surprised about Jim being right again. He won't be able to fit his head through his shop door today.
Sorry for delay in responding. Still working on it; can't say it's unstable, currently haven't got the user-defined parameters entered in a combination that produces a spark at the desired timing. That in itself makes things erratic - stay tuned (pun).When I installed the GN250 box, I got very unstable timing. When using a timing light, the timing mark was jumping around quite a bit. Is this the same thing happening with this box?
I'm still going over the stuff JP sent me. When you get to that point Larry, I'd like to see some data dumps so we can do some comparisons?JP....just got my unit and wiring it up. Can you confirm how you wired the black wire from the igniter? Did I see correctly that you jumpered the B/W to black in the bike harness connector? (I know black wire from igniter goes to ground)
Caught me out riding...JP....just got my unit and wiring it up. Can you confirm how you wired the black wire from the igniter? Did I see correctly that you jumpered the B/W to black in the bike harness connector? (I know black wire from igniter goes to ground)
