EvenmoreXS
1981 XS650
Quote from 5Twins:
"If the bike spent most of it's life parked on the side stand, that can do it."
regarding squishy forks and low ride height.
I bought some forks...1980's 35mm.... from a bike that had very low miles....Less than 3k if I remember correctly......The bike was part of a private collection....Forks looked as close to new as you can get.... I installed them and have been riding around for a couple months now with no issues with function.
The difference between these forks and the old forks is the ride height and the squish factor. The new forks are much softer and ride lower. They don't bottom out but I keep dragging my side stand on speed bumps and the like. She does dive a bit under breaking but again,,....does not bottom out. Cant be far away though....
I think some new fork fluid would help with the squish and fork travel....but I doubt it would help with the ride height. I don't really want to do spacers.......
Would the bike being on a side stand most of its life compress the springs and cause this lowering......If so.....I think I would consider replacing the springs with the springs from my old forks.....1981 35mm......... because they were a bit better height.
I changed the forks due to a need to replace the fork seals in my old forks but the new forks were a good price and it was worth having an extra set on hand...So i did it.... Forks have been fine but Im concerned that I may eventually meet a hump or driveway I wont be able to get over.
So,
Are these springs interchangeable...80's and 81's.....? Is this recommended or not?
Where would you guys start....?
Also, first time fork worker here.....I can drain the forks from the drain screw on the bottom and once emptied just refill with new fluid from the top with the caps off....7 to 7.5 oz range of fluid.....about 6 inches from the top.....I will likely do fork oil instead of atf or motor......
Thanks everyone. I look forward to a plethora of excellent replies...
So,
