Random frame question - hollow or solid? - see pic
650gts
Atlanta, GA
I'm installing Hugh's CDI system on my bobber and want to mount the regulator on the bottom cross member of the frame. See picture.
Is this hollow or solid? I want to drill and tap so I can bolt it in place. If it's solid I'll look for another place.
You say it’s a bobber?
Looks like a weld on hardtail… those definitely ain’t no Yamaha welds haha
I’d guess it’s hollow. But even if it was solid, why could t you drill and tap it??
Who made the hardtail?? Might get you the answer your lookin for.
Looks like rectangular tubing, I doubt it would be solid. The factory cross member is a round tube with some other shapes welded to it.
Every designer that is sober would use a hollow section there .
It is because the principle of equal strength sections.
But it is also lighter and simpler to work with in the shop.
If you tap on it with a hammer it might respond with a clang
I would not recommend to drill in a load carrying section like that
May I suggest clamp it with flat bars and bolts through the flat bars instead
