My starter don't engage, but does grinding noise. Have removed the RH cover but not the clutch yet.
It seems though, when looking beneath the clutch assembly, that the bendix gear, spring and clip may have already been replaced once, since the clip now is placed according to later specification, that is, to the right of the original mounting place.
But when touching the clip with a screwdriver, it feels very loose, more or less just hanging around the gear. Should it be rattling loose or tight when mounted on the gear? Could this be the issue when it doesn't engage completely?
I also read on xs650wiki that sometimes these problems may be solved by just tightning the clip. And if it has been placed to the right of the original mounting place, one could insert a grip and squeeze it more tight without having to remove the clutch.
Don't want to remove the clutch if I don't have to or order new parts....
