I have a good carb set that is missing one of the brass fuel inlet fittings. I have a junk carb body, and I want to remove the fitting from it, and then JB-Weld it into the good carb set.
Anyone done this?
Any words of wisdom regarding removing the inlet? My thoughts are to put the stripped donor carb body into a 400 degree oven for about a half hour, and then grab the inlet with needle-nose pliers and lever it out. I even thought of Dremeling a round hole into the jaws of the needle-nose to prevent distorting the brass. Overkill?
Anyone done this?
