Howdy yall, So I've got a bone stock 81 650 special II, and I've been having problems with the charging system, if you'd be able to help me out. After replacing the worn out brushes and testing the regulator/rectifier, I've traced the problem to the rotor. The stock one registers les than one ohm on my multimeter, and the one that I got from a salvage yard is from an 82, and reads about 6 ohms. I put the salvage one on, and the bike won't start. I made sure the alignment mark was correct on the replacement compared to the stock and put it on and tightened it up and put the stator and clutch cover back on. It backfired a couples times without starting, and then I stuck the old rotor back in that won't charge, and it fired right up. I tried kickstarting it and electric start, and nothing doin, either way. Any ideas? Is my timing off somehow, or did I just get a screwy rotor?
