You can use the Mikesxs coil # 17-6822 (4.5 ohms primary). No need for the dual lobe cam. Keep using the stock single lobe cam, and keep using both sets of points. Disconnect one of the black wires coming off the capacitor (condenser). Both points will use just the one capacitor. Both sets of points are tied together in parallel, wired to one side of the coil primary.
Also it would be a good idea to add a 10 amp fuse into the brown wire that feeds power to the Kill switch (engine stop switch).
