rwingsfan
Xs 650 Dummy
Ok, back story is my 81 bobber with a Hugh's handbuilt 277 rephaser. Had some running issues that have a least been somewhat rectified and is running acceptable now. Was not charging before and ended up changing out all my wiring, checking and double checking ground. Now everything is good except when I plug in a headlight. When I do it seems to even refuse to charge. I can unplug the headlight and can check anywhere in my system, even at the headlight plug and it is solid voltage and shows charge on the voltmeter. Soon as you plug it in voltage drops badly and won't charge. I have tried a couple different bulbs with no change. I can even put the voltmeter leads in the headlight plug and it is solid with charge, stick a bulb in and all goes to hell. All my other curcuits are good (tail, brake, ignition) This one has me a bit stumped. I have a good solid ground, it is grounded directly to the motor. I guess the only thing I have not tried is running the ground all the way back to the battery, should not have to, should I? Any direction is appreciated.
