79XStLouis
So I did a full restoration on my 79 XS, and it was running absolutely great for a few days. Soon it didn't want to idle without goosing the throttle. When I rebuilt the carbs, both sets of floats had pin holes which I carefully soldered up, but the brass was frail overall, so now I suspect one may be taking on fuel. I am not getting any fuel leakage out of the carb bodies, wouldn't that happen? The bike runs great at speed, just not idle, but the last time out I was hearing some popping in the exhaust note when off throttle and slowing... then again at idle. So maybe I sprung a vacuum leak. Will do the spray solvent test at the fittings to test for vacuum leaks, but wondered if I should also pull the carbs off and rule out leaking float(s).
