Noidea
I got a tx650 with a sneaky problem. Originally it wouldnt idle and would only stay on with the throttle bieng held. I tore down carbs everything was up to spec. Did compression test was low on both wet and dry test so i did a overhaul. changed the rings and the exhaust valves. When i put the engine back in it ran great 2nd kick and fired up. Idled and all rode it around town the next day and she was purring. I noticed that it was kinda loud because i had set valves to .012 and .006 so i wanted to change to .006 and .003 after that that same original problem came up. So I put them back to.012 and .006 and no dice. I have the same original problem all over again the compression is 130 at both sides cold at the moment I took apart and made sure my carbs were up to spec and nothing. Floats are 25mm o ring is in middle of the needle i have the proper jets in place the idle screw is turn out 3/4 of an turn. what could it be? any help would be appreciated
I noticed when looking at the manuals it says starter jet is .6 what is that? Theres no picture of it in the exploded view not sure what that is thanks
