sweatybetty89
trying my luck with the ricks unit. wish me luck ill have it wired today.
head stud retorque do it on every "new to you" XSgetting a lil oil coming from my bottom gasket on my top end
there is a bit of a whering noise
what is the 1mm of movement on the rod look like and i believe that i am going to be changing to a e type tensioner due to the fact that the d type sucks
Did you do it as instructed, one at a time back each nut off till it cracks loose, then tighten?So tightened my bolts to 30 lbs. The bike needs to be cold to do this? If so I did it wrong second it's still leaking oil. And once I set cam chain tensioner I need to re set timing?
