80 something heritage special. BS34 carbs. vacuum petcock.
Only had the thing running for a few minutes a year ago before taking it apart to clean it up (Didn't rebuild the engine.).
Problem with the left side not firing. Right side, at least at idle and start up works fine. Left side - wet exhaust and exhaust kinda getting warm.
I'm coming from the point of view that at one time this thing was all running right and if I don't change anything other than clean up it should be running again. Big assumption I know.
Ok here's what I'm seeing. Left side won't run until I pull the vacuum hose of the intake gasket leaving a big vacuum leak, THEN it starts firing and running good at idle.
So running WAY rich.
I've mucked with the idle screw and I've tried everything from 1/2 turn to 2 1/2 turns no difference. Rubber o-ring is good on the idle screw (I had to use the dremal cut-a-slot method to get it out, genius BTW whoever came up with that).
Ideas here?
Ideas here?
