TCI Replacement 2020 It Works
Funny thing.
I have seen gifs since the Compuserve days but until today hadn't seen the need to create one .
I want to be able to do it local not the "Cloud"
If a picture is worth a thousand words then a gif should be worth 3-4 thousand.
Precision machine tolerances only here at Eaglesnest Laboratories.:)
This was on @DogBunny 's rat bike. I think the Ghost my be the problem. Looking into it.
I'm having timing advance problems after putting this together. The pin out diagram for the CDI says coil is orange and ground black so I tried switching the red striped white and the white striped black on the opposite side of the plug. Didn't work. But when I look at my pickup the orange and black are connected to it.
GN250 85-01 Air cooled single.
They made a lot of them for a long time so the clone TCI boxes are cheap.
250 cc = 20hp Matching state of tune for a 650 is 52hp so the box should keep up with the 650’s needs.
20 degrees advance
TCI box is cheap enough to keep a spare under the seat.
The electronics mount on the battery box, a much cooler and less vibration prone area vs. the end of the camshaft.
Crankshaft timed so no cam chain whipped timing variations.
Uses stock pickup, rotor, kill switch, coils and wiring.
Non TCI bikes need a magnet added to the rotor and a pickup(single pole will work)
Two Many’s Timing chart
Power draw topped out at 1 amp @12.4v so about 12watts at 5500 RPM.
Power draw is 0 when not rotating then goes up
proportionally to rpm.
Edit
Is polarity sensitive. If your idle advance is to high reverse pickup leads.
Hello,
I just wanted to say a big THANK YOU to Team Junk, Jim, and the others who have developed this solution to a bad TCI.
This thread and wiring diagram was super helpful!
I just got my XS650 running yesterday with the gonzo box. It was pretty easy, I just had to reorder the pins on the plastic wiring plug for the old TCI and find a place for the box.
Success!!! The bike runs for the first time in 20 years🥳
I purchased from ebay, item number 146600312920.
P.S. my original hitachi had a few bad components after disassembly and analysis. Looks like a couple caps, a burn resistor and possibly a zener diode. Gonzo box FTW!
I see it came from China. Were there tariff and collection fees?
Since these boxes are of questionable Chineese quality, concider getting a second one and position it so the connector can be connected to either box.
Ebay has a page talking about tariffs, but no detailed breakdown of what exact portion of the purchase price the tariff adds.
Why do you question the quality? The ebay seller has “high quality” watermarked right onto the item photograph 😜
We’ll have to wait another 25 years to see who did it better, 1981 Hitachi from Japan, or 2026 no name from China.
I’ll bet a dollar on the Chinese board🤑
