sweatybetty89
so i have a 77 xs D and it was going well until one day noticed that the shifter was not returning to center. well i go to inspect the problem removing the side cover and unfortunately pulling out the kick shaft as well. so after getting it replaced and seeing nothing wrong notice that the shifter is not as tight as it should be on the shaft causing it to rotate on it. tighten that bolt all is well.
before all of this i had tried kicking my bike over and was getting really bad kick back. It started little by little. mind you I had recently had problem with the timing and had one or the other cylinder getting too hot so.. checked my cam chain adjustment, gapped valve by spec for year of bike and model, checked points gaps, did static timing adjustment.... BOOM all was well for the time being till bike sat for a bit and started to kick back about almost every other kick. get on the forum to see what may be the problem see a lot of talk about timing. So, off with cam chain nut then to the points cover. While trying to get the points set they will not even get close to the mark. I run out of room to adjust them trying to move the top one with the big plate now they will not get any where near the fire mark. Before i had them set dead on and I really thought this was going to be the maiden voyage of ol beatty to see where she stood on the road for a few minuets ( by no mean entirely ready just a test ride) and it feels like i took 10 steps back. i have been very discouraged by this and have not worked on the bike in a couple weeks really need some help guys really need a win to push forward. i wanna see this ol girl on the road again. I know i can do it with a lil help
