leighd42
I found this handy calculator yesterday at Tacomaworld.com. Perhaps you have already seen it but I thought I would share anyway. With this calculator you get a visual comparison with overlay and all the ratio information for your front and rear tire size choices. I entered the info for the factory std tire size 90/90-19 and 110/90-18 then played with the tire sizes to see what combination tires would fit on our stock std rims while trying to keep the ratio of tire diameter the same as stock. It seems that a 100/90-19 and 120/90-18 combination is almost identical diameter ratio as 90/90-19 and 110/90-18 but you will ride about 3/4" larger in diameter. I was considering a 100/90-19 with 110/90-18 since 90/90-19 is harder to find but this combination results in a taller front than rear wheel which I think will slow down steering.The page quickly shows how your chosen combinations will affect rollout with a handy speedometer correction chart too.... Anyway I will be running Pirelli Sport Demons on my cafe this spring. Since I can't get a 90/90-19 in the Pirelli ,I will get (F:100/90-19 and R:120/90-18) to replace my center groove split Avon Roadriders.
DL
DL
