Recently I was fortunate enough to accquire an TX750 swing arm which I want to install on my '75. Does anyone know if an Omar's rear disc brake kit will work with this? I don't see why not but.....
Also, my I like the look of the original front fender on the '75 but have a set of 35mm forks for it which if I understand correctly will improve handling. Any thoughts on how to fit the original fender to the later forks? I could have tabs welded onto the later forks but have some concern about distortion. What about machining out the 34mm female part of the fork to accept a 35mm fork tube?
As always all input is appreciated.
Thanks,
Thanks,
