YL82
Perpetual Restorationist
I learned that a .3145" straight-flute reamer worked fine for my valve guides on the Exhaust side, but I had to order/use an 8 mm reamer for the valve guides on the Intake side since the Intake Valves would not begin to go through the guides after reaming with the 0.3145" reamer. I wondered whether I had ordered the proper Intake Valves (i.e., new OEM from EBay).
i had not realized that the OEM Inlet Valve Stem Diameter is slightly larger than the Exhaust Valve Stem Diameter.
From Haynes Manual:
Inlet Valve Stem Diameter: 7.795 - 7.990 mm (0.3140 - 0.3148")
Exhaust Valve Stem Diameter: 7.960 - 7.975 mm (0.3134 - 0.3140")
So, the ID's for my guides on the exhaust valves are a little snugger than they otherwise would have been if I had used the 8 mm (0.31496") reamer on them. Not a bad thing I suppose.
From Haynes Manual:
